Hey guys, it's been awhile since I've posted here!
![]() I've got some leftover parts available and I really need the money badly, so hopefully there is some interest in these. If you are going to use Paypal, please add 3% to the total to cover the fees. LTPWS Sensors. These came out of the '90 ZR-1 I had. $60 each + shipping. All that is left of the blue sensor is the band and the circuit board. $10 + shipping for just the one band with no sensor. ![]() ![]() Set of timing chain tensioners, they just need to be reset. SOLD to GC Last edited by bdw18_123; 11-24-2013 at 02:32 PM. |
Rubber piece that goes on top of the 2 PCV valves. $12 + shipping.
Crankshaft timing chain gear. SOLD to GC. ![]() ![]() Camshaft gears with plates, pins & washers. SOLD to GC Front timing cover for '90-'92 LT5's. There are some marks above the crankshaft hole and the water pump impeller ground into the cover a bit, but it looks to be still useable. All gasket surfaces are good. $50 + shipping ![]() ![]() Last edited by bdw18_123; 11-24-2013 at 02:33 PM. |
Timing chain idler gear. Bearing still feels smooth. SOLD to GC
Primary timing chain guide. $40 + shipping
![]() Secondary timing chain guides. The two smaller curved guides have the bushing and the wear strip is intact. The longer curved guide also has the bushing but one of the attach points on the wear strip is broken off. The long straight guide has no bushing and no wear strip, but the roll pin to attach the strip is included. $50 each + shipping ![]() ![]() Last edited by bdw18_123; 11-24-2013 at 02:33 PM. |
I would like both the tensioners and ALL the timing components. Would you accept $500 for that lot? GC
Tensioners, full cam gear setup, center idler gear & crankshaft gear SOLD to GOLDCYLON.
Ben Paypal sent. GC
Ben all parts received thanks. GC
#9 |
#10 |
![]() Join Date: Sep 2013
Do the wheel sensors have enough slack to fit 18" wheels?
