I recently finished a extensive plenum pull
https://www.facebook.com/media/set/?...1&l=8f46fa4533 Now I have put over 1000 miles sense and the car was running great, but I just finished a 500 mile trip and got back it ran fine. but today it started fine ran good then I turned on the power key and no difference in power like they weren't opening matter a fact I would hold WOT and every now and then in the upper rpms it intermittently fall on its face. it idles fine starts up fine. what the heck?? Dave |
DTC History codes?
good point ill check the pump tomorrow
Dave |
![]() Join Date: May 2007
What year is the ZR-1?
Okay when I get back in town my first check will be the pump. So my next thing will be the power keys contacts (cause my dash light dose light)?? Well of course besides pulling codes.
Dave |
#8 | |
David check the pump first If your Green LED is lit next to the full power script on your radio surround valet key.... then the valet key power module is working correctly. Have you been able to pull any codes from the ALDL ??? That would point to a secondaries failure and a SES light in the DIC? If not then make sure the pump is working.
#9 |
#10 |
Ok let us know so we can advise you further.
