Old 09-04-2006   #1
tf95ZR1
tf95ZR1's Avatar
Default Plug Wire Lengths
Just changed out my spark plug wires. The new set is not numbered
like the "LT5" set was, and the instructions said to change one wire out
at a time. This doesn't work the best as the lengths DO NOT go in order.
Some were shorter and some were longer.
So FYI this is the order longest to shortest, measured
from the stock "LT5" set:
Longest:
1
4
2
3
8
5
6
7
Shortest
Hope this helps when/if you change out your wires.
C Ya
Ted Feder
