08-25-2013 | #1 |
Crankcase Vent Cover Removal
I recieved a top end gasket kit from Jerry's and it included the gasket for the crank case ventilation cover under the plenum. When I saw that the AC compressor was mounted to it I figured it would be a PITA to replace and better left alone. Is this a gasket that should be replaced? The car only has 25,000 miles on it and it is a 1995.
Thanks
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp |
08-26-2013 | #2 |
Re: Crankcase Vent Cover Removal
It is a place that regularly leaks from what I hear. My 91 with 12,000 had some seepage but nothing major when I did it a couple weeks ago. You don't have to remove the compressor or disconnect the lines. Just remove the mounting bolts and slide it over a few inches to access the cover bolts under it.
1991 ZR-1 #85, 21,000 miles 1991 Z28, L98, 62,000 miles 1996 Collector Edition Convertible, 87,000 miles |
08-27-2013 | #3 |
Thanks!!
