08-15-2013 | #1 |
Front Inner wheel wells
As most of you read in a previous post I made, while on my way to Marc's I had the good luck of killing a road gator in the process it cracked my left front inner fender well. I have spent the last few days looking for a new one problem is they are all black part # 10255287. Mine are gray? I have found out the 88-90's # 14104001 are all gray. There does not look to be any major changes other than near the radiator and slotted outer mounting holes.
Could I get you 90's and early 91's guys to look and confirm if your front inner wheel wells are gray or black? I just wonder if GM modded the first 100 or so Gray 90's ones to fit the early 91's mine is #118. If all else fails I will change both to black but would prefer to keep it original.
08-16-2013 | #2 |
Re: Front Inner wheel wells
Looked at my 90 #2066. Left front liner is black. Mounting bolts look to be like yours.
08-16-2013 | #3 |
Thanks, odd I wonder how I got gray on L & R
08-16-2013 | #4 |
Looked ay my 90 #1755. They are black also.
08-16-2013 | #5 |
My 90 #903 are black.
08-16-2013 | #6 |
thanks, looks like at this point I may be buying both...just my luck!!!!
08-16-2013 | #7 |
First thing to check is the casting information on your "old parts"! There will be casting information for sure! Then you shop for a match! The 14104001 can be had - drop me a PM!
08-16-2013 | #8 |
My eyes aren't the greatest any more, but it looks to me like my black liners have #14104001 on them?
08-16-2013 | #9 |
I had never seen "gray" but I wouldn't argue it. I'd think some sort of treatment has discolored the original and I would have thought that the fascia change from '90 to '91 would require a different wheelhouse liner anyway. I've never physically tried to fit one to the other so I wouldn't argue that either. My '90 is #673 and they're black and at daylight I might actually check for a casting.
08-16-2013 | #10 |
