Old 08-15-2013   #1
KJL
Default Chip Identification
The chip mounted in the ECM box has "SST" on it. It is supposed to be a performance chip. Is there anyway to identify?
1995 ZR1 #159
1992 ZR1 #280
1996 Collectors LT4 (Stock)
572 rwhp
Old 08-16-2013   #2
PhillipsLT5
PhillipsLT5's Avatar
Default Re: Chip Identification
http://www.zr1specialist.com/HAT%20W...librations.pdf
Old 08-16-2013   #3
KJL
It appears I have a memory adapter from Moates.net that looks to have the stock GM BMCB 1620 9008 chip installed on the side and the SST chip on top. I guess I will just replace this with the Haibeck chip instead.
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 08-16-2013   #4
WVZR-1
That "piggy-back" could have been used for several different reasons and yes you would just replace what's there with a new product from Marc.
Old 08-21-2013   #5
Vetman
Vetman's Avatar
Can I replace just the chip with Marc's or do I replace the whole ECM?
1990 Z # 2441
1959 c-1 230 HP 4 speed frost blue/silver 3 owner
2011 cts-v 556 HP, manual 6 speed
1955 chev 2dr ht PP 265 3 speed w/OD
Vetman is offline   Reply With Quote
Old 08-21-2013   #6
WVZR-1
All you need is Marc's PROM
