Old 08-22-2006   #1
tf95ZR1
tf95ZR1's Avatar
Default Spark Plugs/Wires
1)With my top end off, I removed the spark plugs:
denso iridium IT20's and after only about 2k miles
I was surprised to see them all dark black "carbon-y".
Think I should go hotter to IT16's? Gapped @ .050
2)About 60K on the original LT5 spark plug wires.
Think I'll throw them away. Put your tongues back in-
only kidding. I have a set of Taylor 8.0mm wires.
Anybody use these before? How do they compare
to, say, Magnacore?
TIA
Ted Feder
Old 08-24-2006   #2
blackjack
Default Re: Spark Plugs/Wires
we`ve been using taylor plug wires on our bikes for years,and my z has a set...( red,of course) i am totally satisfied with them,as they are very high quality...i recommend them...they also look similar to the stockers.
blackjack
Old 08-24-2006   #3
tf95ZR1
tf95ZR1's Avatar
Thanks, Blackjack. I think I'll put 'em on..........
Ted
Old 08-25-2006   #4
guinnessdood
guinnessdood's Avatar
Lightbulb Re: Spark Plugs/Wires
to, say, Magnacore?
TIA
Ted Feder
1.) Contact Marc Haibeck or Corey hendersona regarding your plugs.
2.) I installed the Red MSD wires...they are a little long (hid the extra length under the plenum) but they look nice. The Taylor wires are good wires too. Then again...so are the Magnecores. Bottom line...if you buy some good quality wires that look nice to you...they will be good. Most of the high quality wires out there will be far beter than the stock wires. After 60K miles...I would change them too....and of course save them...for the NCRS fellas. I have a set saved too...with 20K miles on them.
Uly
Uly
Past OWNER 90 ZR-1 #0120 Red/Saddle
UT Plate: EZR1DER
guinnessdood is offline   Reply With Quote
