Anyone ever intall a Dayco 89298 belt tensioner? It looks the same except I think the spring is installed opposite: (Dayco 89298 is NOT the same and will not fit the LT5, it is for an L98. However you can use the guts from an L98 tensioner and swap them for those in your discontinued LT5 tensioner; Please note, Dayco 89298 has also been discontinued - ZBrink)
http://www.ebay.com/sch/Belts-Pulley...&_skc=50&rt=nc Thanks. Last edited by ZBrink; 01-24-2025 at 01:34 AM. Reason: incorrect information |
Not that I can recall. I wonder if the photo is reversed?
Reguardless it would not hurt to ask if the part crosses to GM Part number is #10067479 which is NLA
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 07-25-2013 at 12:10 PM. |
It is about $35 at Advance, so I will special order it and see if it can be reversed or if it is correct to begin with. It sure looks the same...
![]() Join Date: Jan 2009
I got the tensioner, and it is reversed and the tab on the back plate that keeps it from turning when it is attached to the block is different. However, if you are mechanically inclined, you can bust the new tensioner apart and swap parts out on your existing tensioner. Mine was squeaking making the engine sound pretty crappy. All the grease on it was shot/solidified. The new spring is stronger than the old one, but I believe in my case I could have reused everything and it would have been five with just the fresh grease. The pulley is also the same.
The only thing I would have done different in hindsight would be to use a waterproof grease as it is subject to grease washout due to it's design. Last edited by Blownrunner; 07-30-2013 at 12:13 PM. |
