Old 07-23-2013   #1
Ouchdog
Default Charging pronlem
On my way to work yesterday i noticed that my battery light came on on my 90 ZR1 i put a multimeter on it and only had 10.50 volts with it running. I assume that the alternator is shot so i ordered one. I am going to replace the battery also. My question is can i replace the alternator without pulling the plenum and just pull the throttle body extention off. I dont think i have what it takes to pull the plenum you guys make it sound pretty hard.
thanks
Paul
Ouchdog is offline   Reply With Quote
Old 07-23-2013   #2
Tyler Townsley
Default Re: Charging pronlem
It can be done w/o taking off the plenum but takes some patience on one of the bolts.
Tyler
Old 07-23-2013   #3
Schrade
Welcome onto the boards there.
Was the BATTERY at 10.5 volts? Or was the Field Output on the alternator at 10.5 volts?
