Old 07-18-2013   #1
secondchance
Default Yun's rear brake upgrade - part 2
Some after pictures:
Old 07-19-2013   #2
ScottZ95ZR1
ScottZ95ZR1's Avatar
Default Re: Yun's rear brake upgrade - part 2
Sweet! I'm jealous....
ScottZ95ZR1 is offline   Reply With Quote
Old 07-19-2013   #3
HAWAIIZR-1's Avatar
Yun,
That is just AWESOME. As they say in Japan, "SUGOI". I imagine that won't fit inside of Dymags............
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 07-19-2013   #4
Those calipers look very similar to the Camaro Brembos. What did you need to do to adapt them? Same as the C6Z?
Old 07-19-2013   #5
secondchance
Yun,
Diameter won't be an issue. Spoke - I don't know. If I had an access to someone local w/ Dymags would be easy to find out for sure.
Old 07-19-2013   #6
secondchance
Part 1 post, 1st pic shows a steel bracket necessary to mount e-brake caliper and 4 pot caliper.
The bracket was a part of kit sold by Revolution Brake.
Old 07-20-2013   #7
HAWAIIZR-1's Avatar
Thanks for your thoughts Yun, not sure also the difference between the Gen I and Gen IIs for clearance with big brakes.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 07-20-2013   #8
Nice upgrade for the rear. If you don't mind me asking what's the price point? Is the e brake retained?
Old 07-20-2013   #9
WVZR-1
The e-brake is at 12 o'clock!
