Old 07-08-2013   #1
voxdeidave
Default Looks like my left bank Cat just died
Looking for some advice...
My left bank cat converter just kicked the bucket....I've been picking pieces of the honey comb out of my tail pipe for the last few days.
Trying to decide which route to go. Pennies are a bit tight at the moment, but I don't want to simply leave it for fear of any further damage.
I'm running classic plates here in PA, so I don't have to worry about trying to pass emissions. If I go ahead and clean out the left cat since its already toast should I do the same to the other bank? I'm sure the imbalance in back-pressure is not the best thing...
Thoughts?
Dave
voxdeidave is offline   Reply With Quote
Old 07-08-2013   #2
Default Re: Looks like my left bank Cat just died
Time for a set of long tubes dont throw anymore money into the cats.
Old 07-08-2013   #3
Paul in SC
Paul in SC's Avatar
Second on that. I blew out a cat on my '91 and the cost to replace was crazy. Went with the headers; much better for the performance and sound anyway.
Paul
1993 ZR-1 - "The Green Thing", LPE/LSV 385; 2021 HTC, Red Mist Metallic, Cool gray interior, stainless dual stripes; ZR-1 Net Registry #1376
Paul in SC is offline   Reply With Quote
Old 07-08-2013   #4
I agree with both bit....
If times are tough, take the insides out of both and make sure everything is out.
You might be able to find a replacement piece cheap too...
See you @ Carlisle Dave??????
Old 07-08-2013   #5
I think there is a set of 94 exhaust manifolds on ebay; $249.....have a pipe put in instead of the cats, bet you pick up some decent powers for low price
http://www.ebay.com/itm/93-94-95-C4-...ht_1169wt_1018
Old 07-08-2013   #6
Lee he drives a 91 Id still suggest the long tubes
Old 07-08-2013   #7
tpr60
I have a set of cats that are gutted from a 90, we could work out a deal for your good cat as they smog all cars for ever here in Calif.
tpr60 is offline   Reply With Quote
Old 07-08-2013   #8
Note says budget is tight, 94s would work also; 90s-92 exhaust does not look nearly as good in terms of build quality; pipes pinch alot
Old 07-08-2013   #9
Corbusa
Ditto GC
Old 07-09-2013   #10
voxdeidave
Hey David.....you bet I'll be there for Carlisle!!!! wouldn't miss it!
