Old 06-26-2013   #1
mgbrv8
Default strange surge
When coasting fron 30mph to around 5mph in neutral either with clutch in or out the engine surges until you slow to around 5mph and then it smooths out. Now i just replaced all the injectors with new delphis, rebuild the entire secondary vacum system, replaced the map sensor and anything else I could think of under the plenum. Now the car did this before I did all the work but it was more prone to dieing when it was surging and the surging was more erratic then. Dose anyone have any idea what it might be.
Here is the video of the surge
https://www.facebook.com/photo.php?v...42547347021421
And here are the pictures of all the work I have done so far
https://www.facebook.com/media/set/?...1&l=bf12a0aa41
Dave
Old 06-26-2013   #2
mgbrv8
Default Re: strange surge
I was thinking new O2 sensors maybe??
Dave
Old 06-26-2013   #3
What PROM (MEMCAL) is in the the car?
Old 06-27-2013   #4
mgbrv8
What ever came from the factory.
Dave
Old 06-27-2013   #5
I think it was an issue in the OEM memcal and there was an updated MEMCAL to fix that specific issue
Old 06-27-2013   #6
Hammer
Hammer's Avatar
Talking Re: strange surge
It's not the chip. The engine would idle high for a bit and then settle down to normal, not surge like your's is doing. The later chip fixed that and Haibeck's chip does too. Call Corey or Marc and run it by them unless someone else has a fix, I don't.
TPS maybe??
Old 06-27-2013   #7
scottfab
scottfab's Avatar
Surges? Try simple stuff first.
Clean the IAC and the pathway into and out of it on the TB.
Scott
Old 06-27-2013   #8
mgbrv8
I dissasembled and cleaned the throttle body completely and the IAC. now I did order a new IAC and o2s it's on it's way we will see what that dose. Oh one thing this car has headers and O2 extensions
Dave
Old 06-27-2013   #9
tf95ZR1
tf95ZR1's Avatar
Dave
I remember reading that many people un-knowingly clean off some goop
from the throttle body butterfly shafts. This is supposed to be there (Dap?)
as a vacuum seal, else a leak.
Old 06-27-2013   #10
TPS maybe??
thanks I could not remember what issue the chip fixed.. that is why I stated I Think.. since I was not sure
