![]() Join Date: Jan 2004
Ported 91 (will fit 90-92) Plenum and Injector Housings
Bolt on 20+ rear wheel horsepower! $1500 outright or $900 + exchange for your unported parts ![]() ![]() ![]() ![]() ![]()
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 Last edited by Locobob; 06-18-2013 at 03:14 PM. |
![]() ![]() ![]() Join Date: May 2007
Bob what level of port is this ?
This is designed to go on a stock or mildly modded 350 cid. Pretty much anything else is going to have ported heads and you'd want to match the intake to the head porting. It's 36+mm throughout except for the primary runners which funnel down from 36mm about half way down the injector housings to 34mm where it meets the head - stock primary head ports are 32mm at the gasket surface.
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
![]() Join Date: Apr 2007
Robert,
Excellent work! Tell us how you managed to finish the runners inside the plenum?
#5 | |
![]() . . . . . . . . Well okay.... this pic should explain it... and yes it is a very time consuming pain in the *** to do. ![]()
#6 | |
If primary head port is 32mm, what is secondary head port size (stock)? I ask because I'm limited with respect to work in the head, can only go in one inch. That would seem to be enough to take up the 32 to 34mm... Hmmm... Mo Powah - tasty! - Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's DRM chip/Watson/Borla/lid/LW batt&headlights, springs, shocks, pads & lines, quick rack & Turn One, camber brace, 32/22mm sways, A/C halfway deleted 17x11 & 12 CCW's, 315 & 335 Hoosier A6s [/I] |
#7 | |
![]() Join Date: Mar 2004
Me likey
#9 |
#10 |
Forgot to mention that I went ahead and opened up the plenum throttle bores to 2.5in so if you have or may get a 63mm throttle body someday you'll be good to go with this.
