Old 05-24-2013   #1
Corbusa
Default A couple things wrong today
I took her out to stretch her legs... and the seat belt indicator stays on . ( yes they are plugged in..) any ideas ? and a lite on the dash INFL / REST stays on...? any ideas .. also I'd like to get rid of the antenna ,best options? I hate the smokey and the bandit Trans am look .. even tho it is my 2nd favorite car. Thanks Guys ..
http://www.hotrod.com/eventcoverage/.../photo_03.html
Old 05-24-2013   #2
Kevin
Kevin's Avatar
Default Re: A couple things wrong today
I think the inst/rest light is the airbag and the connections are under the battery and just need scrubbed with a wire brush and you should be ok
Old 05-24-2013   #3
Corbusa
Correction it was INFL/REST.
Is there something under each seat that tells the car there is weight in the seat in order to buckle up?
Old 05-24-2013   #4
BigJohn
BigJohn's Avatar
No!!!
Old 05-24-2013   #5
WVZR-1
Nothing that triggers "occupancy"!
You have no "INF REST" in the DIC only the red in dash? DO you have both? If there's an issue with the SIR (INF REST) the SEAT BELT in the dash (red) will also light. If you've only the (red) in dash then it's a seat belt issue. If both DIC & dash it's SIR and most frequently is the grounds of both sensors to the frame rails. I'll not mention the cleaning that's covered many, many times.
You mention "get rid of" antenna. Do you just want to defeat the power mechanism to keep it down? If that's the case you can just put a demand switch in-line so if you're not an AM/FM listener there's no need for the mast to be up. -=Jeff=- and a couple others have done alternative antenna locations but with what results I'm not sure. I believe location would have a lot to do with "satisfaction".
Old 05-24-2013   #6
Corbusa
Thanks guys I have the red seat belt symbol and yellow in the display area that has the INFL/REST.. So I guess both .. I'll look for a thread on cleaning the grounds / sensors on the frame rails..
Old 05-24-2013   #7
scottfab
scottfab's Avatar
Here is one:
http://www.zr1netregistry.com/Inform...-REST-fix.aspx
But also you might want to check the two plugs under the dash on both sides.
Look for a bright yellow wire then trace it to the plug. The pins have gold plating but
I have noticed that on a few occasions by unplugging and plugging them back in
the problem went away. I then coated them with dielectric grease and that did it.
So both the frame rail cleaning etc and these connectors should be considered.
Scott
Old 05-24-2013   #8
Most of those grounds for the dash, etc are located on two lugs, either side of top center of the block directly above the clutch bell housing.
They are a bit awkward to get to, but if you pull the PVC and MAP sensor off (no biggie) then you can get reasonable access to those bolts and the grounds you're interested in, I believe.
Shine them with a wire brush or emery cloth, and coat them with dielectric grease before attaching them again.
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 05-24-2013   #9
Funracer
P.
http://www.zr1.net/forum/showthread.php?t=19869
Funracer is offline   Reply With Quote
Old 05-24-2013   #10
Corbusa
Thank you Gentlemen... I hope I remember all you have said.. I am leaving out of town for a few weeks and will tackle this as soon as I get back.. Isnt it funny how life treats us? Both my trucks are having issues , both vettes, both lawn mowers & all at the same time. yet I cant complain, I do regular maintenance on my equipment and toys . my riding mower is 34 yrs. old but everything took a dive all in the same week .... I'm headed to TX in my junky S10 cross yo fingers for me... Thanks for the info.
