05-12-2013 | #1 |
Made a vid of my "flywheel noise" , is it the flywheel? ---
There is a description in the video area for more info on my car and the issue.
I was thinking this was the dual mass flywheel making noise. Its a timed cam car and I heard they are even noisier than usual. Its louder near the end of the vid. I only hear it when the car is warm and at idle. 1990 LPE Topend ZR-1 with 43k miles. THANKS!!! --- http://www.youtube.com/watch?v=ja1Kq...ature=youtu.be EDIT: 2nd vid. -------------------------------------------------------------------------------- I took a new vid of the flywheel from the passenger side after my trip to the track. I can almost picture the weights bottoming out. : http://www.youtube.com/watch?v=jaGDqqvrMjY
[SIGPIC][/SIGPIC] 01' Dodge Viper GTS 11' Ford Raptor 90' ZR-1 Corvette LPE #699 Last edited by alwayscode390; 05-18-2013 at 05:32 PM. |
05-12-2013 | #2 |
Re: Made a vid of my "flywheel noise" , is it the flywheel? ---
Are u sure you're not thinking about single mass flywheel?
05-12-2013 | #3 |
Does it go away when you push your clutch peddle in?
05-12-2013 | #4 |
Do you have headers and is the Air Pump plumbing still in place?
05-12-2013 | #5 |
If it goes away when you press the clutch in then it's possibly the pilot bearing at the tip of the input shaft to the ZF6.
05-12-2013 | #6 |
As far as I know its the stock clutch and flywheel.
The last owner said he didn't replace anything, and there is no info on the Lingenfelter receipt for a clutch/flywheel swap. There are Watson headers on there, and a spot on the drivers side welded up. Where should I look to see if the Air Pump is still in place? I don't think it goes away when I press the clutch in ... I will be driving it again in a few minutes and will check for that. THANKS ---
[SIGPIC][/SIGPIC] 01' Dodge Viper GTS 11' Ford Raptor 90' ZR-1 Corvette LPE #699 |
05-12-2013 | #7 |
My Watson headers have fittings on the primary tubes that plumb together and pipe over to the air pump, which I think was in the drivers' headlight area. I took that out a long time ago so I can only dimly recall.
The one time I got what I now think was a flywheel noise it was hella louder than that. You may have an exhaust leak. Could be the air system. Good luck, - Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's DRM chip/Watson/Borla/lid/LW batt&headlights, springs, shocks, pads & lines, quick rack & Turn One, camber brace, 32/22mm sways, A/C halfway deleted 17x11 & 12 CCW's, 315 & 335 Hoosier A6s [/I] |
05-12-2013 | #8 |
In person I think the noise sounds SO much louder, but when I heard it on the video I was surprised how quiet it was.
I just took a drive, it does NOT go away with the clutch depressed. It is silky quiet and smooth on cold startup ... sound starts up immediately on a 2nd start/warm start. ---
05-12-2013 | #9 |
Do you have original injectors?
05-12-2013 | #10 |
My next thought is that it either does have a single mass flywheel or a bad lifter. I'm leaning more to a single mass flywheel because they tend to get louder as the car warms up.
