![]() Join Date: Jan 2009
I wonder if the "cooked" coils in the valley could be replaced with something like this. It is used on some 2004 Ferraris as well as 2007 Audis.
It is used on some 2004 Ferraris as well as 2007 Audis. Rock Auto has several vendors for same: These list will be updated as needed. The challenge would be: 1. Getting from a waste spark coil design to an individual spark 2. current handling capacity of existing harness 3. hiding narrow gauge wires atop the valve covers 4. addressing any timing issues (probably NA) Advantages: 1. fewer baked coils in the valley 2. hotter spark 3. no HV ignition wires 4. ease of access to coils
![]() Join Date: Jul 2007
Depending on how you would route the harness, you could route it into the valley and keep it out of sight from onlookers..
The Ignition Module does quite a bit in our cars so that would be one challenge the other challenge would be trying to use the 9 slot reluctor wheel in our cars.. F.A.S.T use to make an eDIST for cars like the L98 so I was thinking that might possible work as looking at the ECM the connections to the IM and ECM are similar to the L98 cars
Scott,
this: http://www.megamanual.com/ms2/GM_DIS.htm and this: http://www.megamanual.com/ms2/GM_7pinHEI.htm Might be of some use to you too. The firing Sequencer is the vital piece we would need but I think a sequence of sorts could be made to work along with a typical GM module? maybe
Would it be simpler to relocate the current coil package outside the
engine valley? Re-engineering that might be easier. If this is a dumb idea thats Ok. Just throwing it out there. ![]() |
#5 | ||
#6 | |
![]() Join Date: Sep 2012
#7 | |
Wow, sounds like they had a real quality issue at first. Did you ever hear what the root cause was?
#9 |
#10 |
Audi only told me that they know there's an issue but once they are replaced there's no more problem. In the worst case, I was leaving the dealership after they had replaced the 2nd coil and I made it about 2 miles when the 3rd one failed. I limped back in, talked to the service manager and they went ahead and replaced the last remaining coil while I waited. I went online while I was waiting and found there had been one recall in I believe '08 for coils.
