Old 05-01-2013   #1
Default Initial thoughts on Pete's Intake/Exhaust cam combo
They're very nice.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 05-02-2013   #2
Default Re: Initial thoughts on Pete's Intake/Exhaust cam combo
With each successive calibration update, the car gets more fun to drive. Idle is at about 875-925 but the roughness of it has been calmed down. Throttle is very responsive. Fifth gear feels like fourth or even third. No hesitation when I hit the loud pedal. Moving off from a standstill feels as if there is more bottom end. I can drive the car in 6th gear at 8-900 rpm w no lugging. It's blubbery, but it will pull,until it starts to accelerate more normally. At cruise, the motor is pretty quiet and smooth. A few more runs to hone the tune further but it's getting pretty close. Exhaust note makes radio unecessary. Next up will be WOT.
Old 05-02-2013   #3
Sounds great! Looking forward to your dyno numbers next!
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 05-02-2013   #4
efnfast
Dom, what did you have done?
Old 05-02-2013   #5
Pete
Pete's Avatar
Hi Dom
I hear you need to give the car a push start from stop lights.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 05-02-2013   #6
SSHHHHHHHHhhhhhhh Stop talking about Pete........he's here now !
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 05-02-2013   #7
Originally Posted by Pete View Post
Hi Dom
Pete
Yes you do. There's no low end torque. I'm gonna cut a hole in the floorboard and get some Fred Flintstone sandals so I can get car rolling.
Old 05-02-2013   #8
tpepmeie
Go bigger. You need some 255's on the intake, and at least .500 lift to get the ports working....
I'm planning an upgrade path for the 427. Think 800 N/A is within reach? Who needs streetability?
T
Old 05-02-2013   #9
The new Ford 5.0 DOHC uses performance cams with .497 intake lift and .453 exhaust.....
Old 05-02-2013   #10
T
Todd,
Actually Pete's current cams are larger than these. He tells me the cams now installed on my motor are the ones that did a 129 trap. He thinks he's at a six of one, half a dozen of the other situation on cams for a 5.7L motor.
Would you keep exhaust as is, or go bigger on yours? What overlap are you planning on? Be interesting to get Behan's view
