Old 04-28-2013   #1
alwayscode390
Question Is the tensioner for the serpentine belt supposed to move a lot? ---
I noticed while my engine was idling today I could hear the tensioner bearings ... they didn't sound horrible but it made me look for the tensioner.
When I found it , it was moving side to side quite a bit trying to keep the serpentine belt tight?
I popped the hood initially because the belt was slightly squeaking ... but it was humid from a storm lastnight.
Is this normal or should I be looking for a replacement tensioner? If so , who do you recommend I buy it from?
Thanks ! ---
alwayscode390 is offline   Reply With Quote
Old 04-28-2013   #2
Marc Haibeck
Default Re: Is the tensioner for the serpentine belt supposed to move a lot? ---
The accessory belt tensioner on the LT5 normally jumps around quite bit. This is usually caused by the belt. The tensioner arm load is 12.5 ft. lbs. at full swing. Measure it with a torque wrench in the square service hole. It's much less than most other cars.
Look for plastic strips emerging from the tensioner pivot area. That's a common failure mode. The pulley is readily available, Dayco 89003.
Best of luck.
Old 04-28-2013   #3
Thanks ! ---
Start looking. The pulley are available however the idler arm are NLA. GC
Old 04-28-2013   #4
alwayscode390
Thanks guys ---
Old 04-29-2013   #5
scottfab
scottfab's Avatar
Thanks guys ---
I was looking the other day.
Rockauto shows 6 different models available ranging from $6 - $18.
These are pulley only parts.
Scott
Old 04-29-2013   #6
alwayscode390
What part usually breaks though, sounds like the actual tensioner at the pivot area?
Is the Pulley what has the bearings ... so if it gets loud its time to replace the pulley itself? I looked at pics of the pulley , and it looks like the center of it has sealed bearings (unless I was looking at a generic pic , not an actual pic).
Thanks ---
Old 04-29-2013   #7
Thanks ---
The pully has the bearings
Old 04-29-2013   #8
scottfab
scottfab's Avatar
Thanks ---
I've had movement like that where it turned out to be just the belt.
But then I've had movement too that turned out to be the pulley.
(different vehicle) I've never seen an issue at the pivot area.
Scott
Old 04-29-2013   #9
efnfast
If I remember, Marc rebuilds these.
Old 04-29-2013   #10
Fully Vetted
Fully Vetted's Avatar
Yep - Here ya go:
http://www.zr1specialist.com/HAT%20W...0tensioner.htm
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
