Old 04-28-2013   #1
Don in VT
Default Quick question on the 90 A/C
Hi All,
Quick question on the 90 ZR A/C. Is the compressor clutch cycling switch (the switch right near the evap housing) the component that sets the 09 (low freon) code in the diagnostics menu ? If not, what other switch/sensor will set the code ?
Cheers,
Don
Don in VT is offline   Reply With Quote
