![]() Join Date: Apr 2012
I have a '91 ZR-1, I do not have any codes and my system seems to be working as it should.
My car has a DRM FX3 Controller and a Bilstein programmed AK2116 (chip and controller) for 92-95 FX3 cars. My shocks have been re-valved by Bilstein to match the controllers program. Bilstein provided a customer program B-260 to work with the re-valving of the shocks and my coil over suspension for a complete package. Here's the situation, seems my fronts are too soft in suspension travel. They do not seem to have the same firmness that the rears do when I move the selector switch to "Sport" mode. I get this feeling when I travel at normal highway speeds and I hit a dip in the road. I recently picked up another FX3 controller (89-91 part) and 4 actuators for comparison between modules and chips, for testing only. After reviewing my Bilstein paperwork and looking at the FX3 module, seems I have an FX3 controller for a '92-'95 MY. The cutoff year for the controller was October 91. Cars before this date would require the MY89 to MY91 controller. My car was manufactured late 1990!?!?! Why the '92-'95 controller? Questions: What is the difference between the controllers from MY89-91 and MY92-95. Is it just programming or a physical difference such as wiring? What does Slalom 1 AX2116 actually do? Seems this is the entry level for road racing. Close to stock but a bit more aggressive??? just a guess. What does the Bilstein chip with program B-260 actually do? Again, system works and does not throw any codes. Just curious how the DRM FX3 module and B-260 with re-valving are different from the stock system. |
Well I know the shocks are different for the run stops on the 89-91s vs 92s and up. If you have a 92 and up programmer I am making the bold assumption your running the later shocks as well. Or changed out the top gears?
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 04-25-2013 at 01:04 PM. |
#3 | |
Well look at you! In fact they did change the tops out and I have them in a baggie. Didn't understand why that was done. Now I do. Thank you |
So does this mean the FX3 controller and actuators that I just purchased from a '91 Z are not compatible with my system?
Gears removed from Bilstein. ![]() |
#5 | |
As pictured above those are call the actuator Cups they are also compatable with all FX-3 systems from 89-95 ![]()
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 04-25-2013 at 01:12 PM. |
Missed your picture the first time. I will have to pull the actuator and check.
Thoughts on the controller programs? |
#7 | |
Well my thoughts are this the controller must have been modified to run on the earlier FX-3 systems. The top gear stop lengths are different. I would be interested to know if they changed the top gears of the shocks to accomodate the later controller.
This is the driver side on my '91.
![]() It was tough to get my phone in there to take a quality picture however, the stop length covers 3 teeth on the gear like the '92-'95 shown in your picture. Last edited by boostedmaxPSI; 04-25-2013 at 03:57 PM. |
#9 |
![]() Join Date: Jan 2007
Frank,
I don't remember what # controller did what with DRM but I do remember that one controller I had it did not matter what setting you were in because it was irrelevant . What the customer controller did was in “Tour” you had 50% front and 100% rear shock. In “Sport” you had 100% front and 50% rear shock and in “Performance” you had 100% both front and rear. Now with the stock FX3 system the computer has several different levels within each setting (I don’t remember how many but I think 3). I know that Exotic Muscle still has the custom FX3 computers maybe they could help you as to what program you have going on. With our Rippie car we chose to keep the stock FX3 computer then valve the shocks to the Moracca setting for a more firm ride. It has worked like a champ over the years. What spring rates are on your Z? I know in the past years that a higher rate was normally used. I have seen 700 pound front springs before on a “Street” C4 for comparison I am running 400 front and 275 rear on a more track oriented L98 C4 and it does just fine. I believe most now use a 450 front and 275 rear spring on the front of the ZR-1’s for street applications. Are the shocks bottoming out? How much rake do you have? Daniel |
#10 |
So as expected they are using the later shocks and the later FX-3 module. Makes sense now. What are the spring rates of your coil overs front and rear? GC
