04-22-2013 | #1 |
MS/Raptor Joint ECM Project on track for BG
Final tune is complete. The car with the MS/R ECM pulled 360 RWHP on a totally stock (405 hp) car. This car has No porting and has the stock exhaust. I'll see if I can get a copy of the Dyno Sheet...
BTW - The MS/Raptor ECM play's nicely with the CCM. It's also not the typical ECM that you read about on their website. It's the latest and greatest modified for our cars... Cheers,
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int |
04-22-2013 | #2 |
Re: MS/Raptor Joint ECM Project on track for BG
Here's the prototype:
The connector on the back side is for spare I/O to facilitate non-factory features and functions. The square, shiny metal thing on top of the blue board is a slot for an SD card, to facilitate onboard datalogging. The smaller metal thing just above it retains a battery for KAM memory for the internal RTCC (clock and calender).
04-23-2013 | #3 |
Ron,nice very very nice.
Pete
04-23-2013 | #4 |
very cool, What is the price of this again?
looks like it has some cool features But if the SD card is buried in the ECM, you need to remove it to download it? or is there a direct PC connection to download datalogs?
04-23-2013 | #5 | |
Exactly my thought. There should be a port to the side or?
04-23-2013 | #6 |
Also if I recall, this will allow use of CNP and eliminate the need for the Ignition module and Waste spark system in our cars right?..
EDIT:; is it designed to fit into an OEM case? If so, I am keeping my L98 727 ECMS for a bit, they might become useful
04-23-2013 | #7 |
Looking forward to hearing all the details on the final product.
04-23-2013 | #8 | |
I've asked the question about the SD card and should have the answer tomorrow. From what I remember the Card can be downloaded via one of the ports. Just not sure which. Believe me, it won't be hard...
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int Last edited by RHanselman; 04-23-2013 at 11:51 PM. |
04-23-2013 | #9 | |
We designed the board to fit the OEM case however with the addition of the extra port we had to go with a custom unit. It will still fit in the stock location and have a similar appearance. Keep you old units. I believe Jerry will have a turn-in credit for the old ECMs. BTW - we couldn't source the 4 large connectors that hook to the harness. We're using used connectors that have been inspected and tested to be good. Cheers, Ron
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int Last edited by RHanselman; 04-23-2013 at 11:55 PM. |
04-24-2013 | #10 |
The SD functionality as well as other functionality will be available via the serial port. No need to pull the SD card.
