04-07-2013 | #1 |
Best scanner / laptop software?
What's the best 'stuff' to get a good read on the motor operating parameters? Handheld scanner? Laptop link-up?
Anyone on the boards here got these toys for sale? Preferably, I'd like to go with laptop software with the hardwire interface...
04-07-2013 | #2 |
Re: Best scanner / laptop software?
Well, I imagine the best would be a Tech 1 scanner. After that would depend on how much you want to spend, and what features you want. I spent under $200 for laptop software and accessories, but had to spend a lot of time figuring it out and getting it to work. But I'm happy w/ it now.
Joe 1990 Bright Red ZR-1 #2599 |
04-07-2013 | #3 |
Joe, do you get all codes with the sofware on your laptop?
I read somewhere else the FX3, ABS and AC codes won't read on other readers/scanners. Don't know how true this is or not. Just picked up my 92 LT5 #454 and just learning. |
04-07-2013 | #4 |
Well I got the EFI working properly, and that can read and reset all the ECM codes but not CCM, ABS, or SIR codes, it can also datalog. I still have to dig into the TunerPro, this can re-burn the PROM, read and reset codes (not sure how many), and datalog, but just haven't had the time yet to learn everything it can do.
04-08-2013 | #5 | |
Which setup do most people on the boards here own? Darryl / Dominic - add a poll here???
04-08-2013 | #6 | |
It can pull and read all the codes and reset them. What I'm not sure of is, if it can datalog and re-burn the PROM (and they're fairly expensive). Not sure if it can connect to a pc (if it can, it will probably need a serial connection). Anything you buy for a laptop will not be "real time" because of the multi-tasking the operating systems do (which means, you may have to do a little configuring). I found software that can do OBD I and II for a pretty good price, but it takes a little computer saavy to get them to work on the OBD I.
04-08-2013 | #7 |
Forgot to mention, you can pull and reset all codes (except ABS and SIR) by grounding pin G on the ALDL connector (that puts it in diagnostic mode). The procedure is in the FSM.
04-08-2013 | #8 | |
Thanks there Mr. V... No Tech1's came up with that search criteria 'Tech 1 scanner' , or 'GM Tech 1' , or 'Tech 1' , or 'Tech1' ... ed.: Ok - found one http://www.ebay.com/itm/Original-Exp..._Tools&vxp=mtr $5 C-bills??? yIKeS!!! And a behemoth shipping charge of an addition Franklin GaDZOoks!!! How big is this ? And are they all in the 5C price range? And seller says this is the earlier model. WHAT'S THAT MEAN? Better than the newer one? I can get ENIAC shipped for THAT! Hello laptop. I can compile batch scripts and VBS for what's necessary, I do believe. What DOES everybody here use??????????????????????????
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 04-08-2013 at 10:29 PM. |
04-08-2013 | #9 |
... and I'm asking about Tech1 -> computer interface, to get a printout of logged data, or to post directly to the boards here...
AND I'm not sure I understand that the laptop link-up does NOT read real-time??? Is there a delay of some sort in data conversion?
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 04-08-2013 at 10:33 PM. |
04-08-2013 | #10 |
Not sure what everyone else uses, but here's what I used:
http://www.zr1.net/forum/showthread.php?t=19272
