Old 04-01-2013   #1
Fully Vetted
Fully Vetted's Avatar
Default Leaf spring separation?
I don't know if anyone else has experienced this but I was installing my wheels yesterday and notice what appears to be my leaf spring separating.
Here's the view from the top:
It looks a lot worse from the rear/side:
I'm curious if this is just superficial or if it's something that needs to be addressed sooner than later? I figured I would measure it and keep an eye on it.
What are your thoughts?
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 04-01-2013   #2
WVZR-1
Default Re: Leaf spring separation?
I'd say that sooner rather than later but I believe NOW might be more descriptive of the attention it needs. You need to determine what you would like to do.
Replace it with a take-off and there should be many available probably quite close, maybe consider the upgrade to a coil-over package or maybe even an after-market replacement and there are maybe a couple different choices there also. Decisions!
The spring should be an RHY code that would be '92 - '95 all ZR-1 and a '96 coupe with FE3. You might use that to shop maybe VBP or some others to gather a plan. Your season in Texas is already started I'd think so it's "time" and judging from the appearance in the snapshots, like I mentioned NOW.
If you deal with it now it's a minor inconvenience. If you just "keep an eye on it" it can and will likely bite you, it might not be just an inconvenience then. It could be catastrophic!
Old 04-01-2013   #3
Jim Nolan
Years ago I had seen something close to this on 2 early 80's model front spring. The result of using strong engine cleaners (chemical).
Old 04-01-2013   #4
ZR-1nce removed
ZR-1nce removed's Avatar
I found the same problem on mine 3 years ago when I was replacing my clutch. I called Marc Haibeck and he had a take off part that he sold me. Replacing the spring is a piece of cake. Get new bushings while you're at it. Good Luck
90 ZR-1 #0951 Bright Red (sold)
06 Z51 MN6 Velocity Yellow (sold)
2023 C-8 Z51 ELB
ZR-1nce removed is offline   Reply With Quote
Old 04-01-2013   #5
CJ_ZR1
Removed leaf springs from my car last week. I am in the process of installing coilovers. They look to be in good shape, let me know if you might be interested. I can take a few pics to send ya.
CJ_ZR1 is offline   Reply With Quote
Old 04-01-2013   #6
Daniel_Mc
Daniel_Mc's Avatar
BTW CJ's springs are Z07 springs, it would be a nice upgrade.
Daniel
Daniel_Mc is offline   Reply With Quote
Old 04-01-2013   #7
WVZR-1
Daniel
You mentioned "springs". That would make the rear an NYU? The front would be a what for code? What are the actual codes on the springs I guess I should ask?
Old 04-01-2013   #8
Daniel_Mc
Daniel_Mc's Avatar
I'll check the codes on the springs tonight and get pictures. The front spring is still in the car.
Daniel
Old 04-01-2013   #9
Blue Flame Restorations
I think I would replace that spring ASAP. Doesn't look road worthy any longer.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 04-01-2013   #10
CJ_ZR1
After checking the codes on both front and rear leaf springs they both appear to be stock ZR-1 springs.
Front spring code:
Rear spring code:
Rear spring:
