03-26-2013 | #1 |
secondarries
Hi to all ,
Im going to eliminate secondarries with Haibeck prom - got vacum hadecke with this nassesary sistem....everything will go out Will cruise control - tempomat , afer that still working? Thanks fo repy. Jano |
03-26-2013 | #2 |
Re: secondarries
I doubt that you'll ever regret "ripping out" the secondaries.
I'm sure someone will answer your question shortly.
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 03-26-2013 at 04:02 PM. |
03-26-2013 | #3 | |
Re: secondarries
Everything in PINK comes out. As you can see, the vacuum port on the right side of the plenum supplies vacuum for the cruise and everything else. Unless you have a "kit", you'll need some gaskets and some freeze plugs. I would assume Marc is going to round those up as a package and send it along with the prom, yes? If NO, then be sure to ask him for them, or PM me and we'll get it handled. Jerry...are you reading this? You know the gaskets he'll need, and also the freeze plugs (Dorman 555s, as I recall?). P.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 03-26-2013 at 03:44 PM. |
03-26-2013 | #4 |
Re: secondarries
Good luck with your LT4.9 conversion.
03-26-2013 | #5 | ||
Re: secondaries
See Vacuum Systems (Secondary and Cruize)
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-29-2013 at 10:25 AM. |
03-26-2013 | #6 |
Re: secondarries
Woops..... Another KLUDGE!
03-26-2013 | #7 |
Re: secondarries
Let's see. That means our hp per litre actually goes up!
03-27-2013 | #8 |
Re: secondarries
It's not a kludge if it's well documented and supportable. Just a LT4.9
03-27-2013 | #9 | |
Re: secondarries
P. PS That should be LT5.1 = an improvement in performance and reliability.
03-27-2013 | #10 |
Re: secondarries
