03-25-2013 | #1 |
Part 3 Windshied A Pillar Weatherstripping redux
Start tooling in the WS from one corner to the other. Go slow and let the ends hang until the top corning positions are close
If statisfied stake the top corners. Use a little 3M adhesive on the longer corner pins.. Now tool in the side pillars. (very easy due to large channels) Place some ws adhesive on the lower corners of each side. Now place the two pins back into the lower corners. I use a little adhesive on the back side of the lower area as it holds the pins in place. now snap this section in place. Final result, Total of 90 mins. Best advise is to take your time and remove all the old material. Makes the reinstall a dream. Do not buy the overpriced WS lubricant from MADvet in the small tube. Some dialectric grease is all that is needed to protect the material from time to time. GC Here are the tools I refered to
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 03-25-2013 at 01:14 PM. |
03-25-2013 | #2 |
Re: Part 3 Windshied A Pillar Weatherstripping redux
Great write up, GC. I'll be doing this myself soon. Would it be easier to remove the seats so you could actually stand up in the car or is it not that big of an issue?
03-25-2013 | #3 |
Its not a requirement once you start channeling in the WS after about a 1/4 of the way the rest of it becomes trained and falls into place nicely. The tools make it very easy. The key to success is a fully cleaned channel like I pictured which will take most of your time.
03-25-2013 | #4 |
Nicely done. What a difference.
03-25-2013 | #5 |
No doubt it was getting a little crusty. GC
03-26-2013 | #6 |
So, the WILCOX WS...you like them? Good quality?
03-26-2013 | #7 |
Yes fitment is as good as GM and with Wilcox you know the WS is new. GC
03-26-2013 | #8 |
Great write up GC, thanks . My WS is needing attention
03-26-2013 | #9 |
Glad you found it helpful
