Old 02-18-2013   #1
Default Winter Projects
Took advantage of the 50d day in Chicago today. Replacing rear brake hoses w
SS braided lines. Also draining brake fluid since it was changed I don't know when. Hope to pick rear calipers after having them polished. Haven't decided on
color for abutment brackets, red, black, or aluminum. Thoughts?
Also, took advantage of the day in the garage to hook up RPM, and MAP sensor outputs to my Zeitronix WB output. The display shows Lambda/AFR/MAP V. And now I can datalog WOT w kPa and RPM at 35 fps.
