Old 02-08-2013   #1
Jagdpanzer
Jagdpanzer's Avatar
Default Crankshaft Position Sensor Air Gap Clearence
Looking for information concerning the usual air gap clearence between crankshaft position sensor and the outside of 9 slot wheel machined in the crankshaft.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 02-08-2013   #2
Default Re: Crankshaft Position Sensor Air Gap Clearence
Are you saying that with the spacer its too far apart from the crank?
Old 02-08-2013   #3
Jagdpanzer
Jagdpanzer's Avatar
Lee
Just making sure what I have is with in spec when I get to that point.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 02-08-2013   #4
need to check my eyes, I read that as the "unusual"....not usual as you posted...
Old 02-08-2013   #5
I think as long as the spacer is in place you are good....I did not see anything in the service manual or video....pete might know for sure
Old 02-08-2013   #6
I see Jerrys has different shim sizes, I will keep looking
Old 02-08-2013   #7
ignition module part #1103841 a gap of .020=.050 and ignition module #1103737(early 90) .070-.080
Old 02-09-2013   #8
Jagdpanzer
Jagdpanzer's Avatar
Thanks Lee,
I installed the crank position sensor in the block tonight and the air gap measured 0.024" so I should be good to go.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 02-09-2013   #9
I can't document, but I recall the early 1990 LT5 (first 500??) being the only ones that required a shim? Hopefully someone else can chime in with substantiated information.
Old 02-09-2013   #10
966 had a shim
