Old 01-26-2013   #1
sammy
Default ok the ultimate stupid ? pcv valves.....
which one goes where???? had plenum off for a couple of days and old age set in ..help
Old 01-26-2013   #2
Default Re: ok the ultimate stupid ? pcv valves.....
If your using the OEM hose they are stepped. When you insert the PCV in the right order they will line up. See the stop lines on the PCV valves? Thats so you know which goes where
