View Poll Results: Which Shifter Set-up Do You Have
Stock shifter with stock throw 37 48.68%
Stock shifter modified to short throw 12 15.79%
Short shifter with stock throw (probably zero) 0 0%
Short shifter with short throw 30 39.47%
Multiple Choice Poll. Voters: 76. You may not vote on this poll
Old 11-08-2012   #1
scottfab
scottfab's Avatar
Default What shifter do you have?
Ok let's see if I can get this right the first time since Polls can't be corrected after they're started.
Select more than one if you have more than one ZR-1.
But if you have the same shifter on more than one car you're limited to one selection.
Scott
Old 11-09-2012   #2
mike100
Default Re: What shifter do you have?
Car came w a Hurst. After having owned another c4 with a blue label that shifted like a hot knife thru butter, I can't say that I'm really for it. Had the ZF Doc blueprint treatment on my gear box though and it shifts every time pretty well considering the increased effort on the short stick.
Don't need the short shifter- seems like a gimmick - like the answer to a question that was never asked.
Case in point- 2011 and newer mustangs with the MT-82 trans. factory stubby- short throw from Ford because I guess they finally figured to save you the trouble and give a short throw from the factory....aftermarket came in and offered a shifter with an even tighter pattern! Why? I think people just automatically think the oem shifter is garbage.
Old 11-09-2012   #3
efnfast
Question.
So we can modify the length that the shifter travels, (hence short throw) and we can modify the actual length of the shifter. I would imagine with a short throw, more effort is required to change gears? TIA -Steve
Old 11-09-2012   #4
Paul in SC
Paul in SC's Avatar
Hurst short throw. I had Bill B. do his refurb on the tranny last December and he reconditioned the shifter as well to better match his setup. Also added the crash-thru reverse detent.
After Bill's magic, the shifting is silky smooth and very direct. IMO, I like the shifter over the stock (had one on my '91) because it is more solid with less "slush".
1993 ZR-1 - "The Green Thing", LPE/LSV 385; 2021 HTC, Red Mist Metallic, Cool gray interior, stainless dual stripes; ZR-1 Net Registry #1376
Paul in SC is offline   Reply With Quote
Old 11-09-2012   #5
efnfast
Thanks for making me ask another question Paul in SC.
What is a "crash-thru reverse detent"?
Old 11-09-2012   #6
Paul in SC
Paul in SC's Avatar
It was an addition to the ZF in '95 that removed the lock-out ring on the shifter and added a mechanism inside the tranny that provided extra resistance when shifting into reverse. The Hurst shifter does not provide for a lock out and the gate between 6th and reverse is extremely close. At least it was in the one I had. Bill / ZFDoc said it had been ground down either on purpose or from use that made it even closer. Bill has his own shifter that has a lock-out ring.
I have attached a photo of the crash through mechanism that Bill added to mine. How it actually works I am not sure, maybe someone more knowledgeable can explain. All I know is it works and the adjustments Bill made were well worth it.
Old 11-09-2012   #7
efnfast
So,,,,there is no lock out ring, but it makes you work hard to get into reverse so you don't find it by accident?
Old 11-09-2012   #8
Paul in SC
Paul in SC's Avatar
Exactly! It's actually not that hard and you can't hit reverse while moving forward unless you try real hard! Ask the guys that have the '95 ZF.
The shifter on mine was so bad, it would almost "fall" into reverse if you weren't careful. Either that or you would jump back down to 4th. It was that close.
Old 11-09-2012   #9
scottfab
scottfab's Avatar
Question.
When the stock shifter is kept but throw is shortened the effort increase is barely noticeable. AND the accidental pushing of the CD back into the player goes away.
Scott
Old 11-09-2012   #10
Ronstar
I have short shifter/ short throw. Accidentally voted stock on
both.
Ronstar is offline   Reply With Quote
