Old 11-03-2012   #1
RiceEatingZR1
RiceEatingZR1's Avatar
Default SYS blinking 3 times
I took the Z out yesterday and noticed that SYS was blinking 3 times every 10 seconds (give or take) next to the Speedo. The car appeared to be running ok. restarted later and it went away but I was wondering if anyone has seen this before or knows what would cause it?
RiceEatingZR1 is offline   Reply With Quote
Old 11-03-2012   #2
Ronstar
Default Re: SYS blinking 3 times
Mine did that when battery was very low
Ronstar is offline   Reply With Quote
Old 11-03-2012   #3
Kevin
Kevin's Avatar
Probably the battery
Old 11-03-2012   #4
scottfab
scottfab's Avatar
I agree probably battery but have a tester put on it to see.
Scott
Old 11-04-2012   #5
X4 the battery unless you recently installed an aftermarket radio.
Old 11-04-2012   #6
tf95ZR1
tf95ZR1's Avatar
X 5
That's what mine did
Old 11-06-2012   #7
RiceEatingZR1
Thanks Guys! time to order a new battery. :-(
