View Poll Results: Which coil packs do you have?
AC Delco 53 71.62%
Accel 4 5.41%
MSD 17 22.97%
Voters: 74. You may not vote on this poll
Old 10-17-2012   #1
vilant
Default Which coil pack do you have?
Doing intel for my upcoming fuel injector change. Figure I'll change the coil packs while I'm under there so I can leave the plenum on for a while. I've found 3 types of coil packs
AC Delco p/n 10467067- $41.09ea
Accel p/n 140017- $43.95
MSD Ignition 8226- $44.95
The AC delco are direct replacements I assume. My questions are these:
Which type of coil packs do you have? If it's not AC Delco, what are the advantages of using another type, (if any)? ie. MSD last longer or work better. Is there any other manufacturers besides the 3 I listed?
Old 10-17-2012   #2
Kevin
Kevin's Avatar
Default Re: Which coil pack do you have?
the ones that came with the car
Old 10-17-2012   #3
ghlkal
ghlkal's Avatar
I pulled the plenum off after work today (someone before me broke the connector clips off almost every electrical connector - two outside the plenum and two underneath ... good grief )
Anyway, I purchased AC Delcos. I bought them from Amazon for about $34 each. I figure that at 22 years, it's probably cheap insurance.
Old 10-18-2012   #4
Blue Flame Restorations
Borg Warner
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 10-18-2012   #5
AC Delco. GC
Old 10-18-2012   #6
MSD.
Old 10-18-2012   #7
Jagdpanzer
Jagdpanzer's Avatar
MSD 8224 here.
Can't tell much difference from the stock coils but like the red color.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 10-18-2012   #8
Ronstar
MSD. Screamin Demon also makes some
Ronstar is offline   Reply With Quote
Old 10-18-2012   #9
jimmy b.
jimmy b.'s Avatar
Had an original coil go bad a couple years back, knowing I had to pull plenum I decided to put a better performance coil so I changed them all to Accels.
There's a small tab that has to be removed so they can mount next to each other, easily removed with a hacksaw blade in seconds. Didn't notice much difference than stock coil just hope they last longer...jim
jimmy b. is offline   Reply With Quote
Old 10-18-2012   #10
vilant
Thanks guys. I can't seem to find a p/n for the Screamin demon or the Borg Warner that fits our cars . Most of the sites don't give a sub-model for the Corvette.
