10-13-2012 | #1 |
Clutch Kits
FYI
Amazon.com has a sale on Z Clutch kits. 1990 - 93.5 LuK Check it out |
10-13-2012 | #2 |
Re: Clutch Kits
That's a decent price on an LT5 clutch kit.
Question: Do clutch kits from a standard corvette work with a ZR-1? (I thought they were different?) The kit say's it works on the standard corvette and ZR-1. David |
10-13-2012 | #3 |
Re: Clutch Kits
Need to use shorter pressure plate bolts if you want the car to move after the install. Don't ask.
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I] [I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I] [FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT] [I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B]) 1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I] |
10-13-2012 | #4 |
Re: Clutch Kits
John,
the throw out bearings are the same too? thanks David |
10-13-2012 | #5 |
Re: Clutch Kits
I would assume so, althought the transmissions were different so some investigation would be in order if someone were to order one. Might call Marc to verify.
10-14-2012 | #6 |
Re: Clutch Kits
Only the input shaft is different on the ZF6 for the ZR-1
10-14-2012 | #7 |
Re: Clutch Kits
Pros:
All parts will work pressure plate,throw out bearing,clutch disc etc, of the same model year 1990-1992 and 1993-1995 Cons: You need the LT1 pressure plate screws i have the GM part # just not at this moment. The pressure plates friction plate (not clutch disc) is thinner then the LT5 friction plate. I have installed these and they drive normal but if your going to do some heavy duty racing i would think the thinner friction plate might build more heat then the LT5 thicker plate. Otherwise good to go. I can rebuild the stock LT5 pressure plates. Do not throw them out. Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 10-14-2012 at 05:58 AM. |
10-14-2012 | #8 |
Re: Clutch Kits
Pete you rock
10-14-2012 | #9 |
Re: Clutch Kits
