10-06-2012 | #1 |
Coolant leak
Coolant leak passenger side front..ideas?
10-06-2012 | #2 |
Re: Coolant leak
10-06-2012 | #3 |
Re: Coolant leak
ideas....hum...fix it?
not giving us much to work with here
10-06-2012 | #4 |
Re: Coolant leak
check radiator/overflow hose connection to radiator/ lower radiator hose. how many miles on radiator?
10-07-2012 | #5 |
Re: Coolant leak
Fix it?... Hmmmm that's a great idea!!(kidding).
That's the plan can't tell much from top or underneath Dripping off front crossmember. Just being lazy thought There might be a likely culprit. Water pump and radiator Are both fairly new. |
10-07-2012 | #6 |
Re: Coolant leak
Run the car hard. Get the temp way up.
Jack up and look. Using just a pressure injection cap does not always work if the leak is on the downhill side of the thermostat. Sure hope it's not your water pump again.
10-07-2012 | #7 |
Re: Coolant leak
When cold, put a finger on the bottoms of the hose junctions. I predict one will be wet.
- Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's DRM chip/Watson/Borla/lid/LW batt&headlights, springs, shocks, pads & lines, quick rack & Turn One, camber brace, 32/22mm sways, A/C halfway deleted 17x11 & 12 CCW's, 315 & 335 Hoosier A6s [/I] |
10-08-2012 | #8 |
Re: Coolant leak
I just had to replace my radiator, ~70K miles.
The plastic passenger side tank had separated from the aluminum cooling stack. Saw rust all over the affected area, and a puddle on the floor. About $100 for an OEM replacement good for most situations, up to $600 for a thicker radiator. Lets "discuss" again whether any modifications are necessary for a Fluidyne "drop in" radiator.... Last edited by tf95ZR1; 10-08-2012 at 01:11 AM. Reason: Wanted 2 |
10-08-2012 | #9 |
Re: Coolant leak
Get a pressure tester from your local auto parts store. OReilly, Autozone and others rent them. Pump the system up to about 15 lbs, guaranteed to find the leak.
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I] [I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I] [FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT] [I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B]) 1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I] |
10-08-2012 | #10 |
Re: Coolant leak
Make sure bolts are tight on waterpump
