Old 06-09-2006   #1
8upZR1
8upZR1's Avatar
Default Factory Camshaft timing procedure
Can anyone outline for me the method that the factory used to time the camshafts on these motors? I used the method outlined in the Haibeck article and wanted to know the difference.
8upZR1 is offline   Reply With Quote
Old 06-10-2006   #2
TheLurker
TheLurker's Avatar
Default Re: Factory Camshaft timing procedure
They used pins and had a fixture that actually locked in two holes on the venier and then were able to tighten the cam bolt to the required torque.
TheLurker is offline   Reply With Quote
