My low coolant light is flickering. Im thinking the sensor may be bad bc I have plenty of coolant (side note: the coolant resvior is relatively full is that ok??)
please post directions on how to change coolant sensor and also if anyone knows where to buy one at a good price. Thanks in advance |
![]() Join Date: Jan 2009
Have you checked both the upper and lower reservoir?
The lower one has no sensor. The upper one has the level sensor. It is located at the back of the reservoir next to the firewall. You may want to remove it and see if you can't clean the crud out away from it. Of course you have to take the high reservoir off to do this.
Scott ![]() Vett owner since 1979._It's about the car and the people Last edited by scottfab; 09-03-2012 at 11:55 PM. |
