Old 08-23-2012   #1
RyanChappel
Default No Start Bafflement....
After running perfectly, starting four times today, this afternoon the Z would not crank. The switch turns to on, but the dash/electronics do not light. If the key is wiggled, an occasional flicker will cross the speedo/odo, and one relay on the driver side front of the motor will growl a little bit.
Thinking the ignition switch has failed internally.
Any thoughts..? TIA
Red '91 #1929
RyanChappel is offline   Reply With Quote
Old 08-23-2012   #2
RyanChappel
Default Re: No Start Bafflement...Redux
Just found the thread below from a week ago about this issue...
Helps a lot...
Tx to all who posted earlier...
