Old 08-12-2012   #1
Default clutch engagement; early
My 90 has the clutch engaging right off the the floor....good pedal pressure and fluid levels are ok, master is newer as is slave. Any thoughts?
Old 08-12-2012   #2
Default Re: clutch engagement; early
Bent pedal
Old 08-13-2012   #3
No both cars have the same pedal height, wondering if the slave is bad
Old 08-13-2012   #4
Color of fluid?
Old 08-13-2012   #5
Jagdpanzer
Jagdpanzer's Avatar
Lee,
Had the same problem on my 94 when I changed to a very grabby kevlar clutch disk. After going through a few spindles at the strip I changed over to Center Force dual friction disk and all is well now.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 08-13-2012   #6
fluid is fresh, clear
Old 08-13-2012   #7
sammy
did you ck the condition of the pivot ball?and the fork. . 602 619 3575 fill boudreaus ph will give you the answer
Old 08-13-2012   #8
mike100
On other cars, my experience was that replacement flywheel dimensions and clutch mix-n-match changed the geometry enough to put the friction point way at one end of the pedal stroke. These were cable operated designs though, but that is the first thing that comes to mind. The pivot point is probably a good place to check.
Old 08-13-2012   #9
scottfab
scottfab's Avatar
Did it have this symptom straight after doing the new master and slave?
Or did it develop later?
Scott
Old 08-13-2012   #10
Did you inspect to see that slave seals were oriented properly?
