Old 08-05-2012   #1
Default C6 Z06 brake upgrade
Wow....
After spending a day with ZR-1 brothers in Virginia, we installed a few items:
32mm sway bar
new A arms (with new bushings / ball joints) *polished up too!!
new front hubs
C6 Z06 calipers / 1 piece ceramic brake pads / stock Z06 rotors
There is a huge difference, even with Ceramic pads!
Going to install the rear brake calipers / rotors in the coming week. (can't wait!!!)
Thanks to Yun, Gibby, Mark, Matthew ***(new to most), Paul, Mike **(new), Glen and especialy Rich for hosting this!!!!!
Lots of pictures and will document the C6 Z06 brake upgrade for the newsletter.
You do need larger wheels in order to accomodate the large 6 piston front calipers and 4 piston rear.... WORTH IT!
For asthetics and stopping power
Here is a teaser
* thanks Rich!!!!
** Welcome to Wazoo Mike!!! (he is setting up a C4 ZR-1 road race car)
*** Newest Admiral Blue ZR-1 owner!
Old 08-05-2012   #2
GSJoe
Default Re: C6 Z06 brake upgrade
Very nice, David! As my Dad would say: "Now you can stop on a dime and get a nickel's change!"
GSJoe is offline   Reply With Quote
Old 08-05-2012   #3
efnfast
I'm jealous David.
Old 08-05-2012   #4
DaveK
He stole those pics off the web, they don't look anywhere near that good in real life...
Hard to tell from stock brakes to be honest. Also you need badly fitting "Carlos Fandango" wheels to accommodate the calipers...
1991 #1516 Black/Black
davidmkelly.com
"Speed is often confused with insight." - Johan Cruijff
Old 08-05-2012   #5
Boy that looks tight on the Fiskes! Can we see pics of the adapters?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 08-05-2012   #6
Dom, my apologies. I said the adapters were much larger than C5/C6 adapters, but it's the opposite
See the C6 Z06 adapters (shiny new) and the C5/C6 attached to the caliper
Old 08-05-2012   #7
DaveK
I'm 100% joking - they look great, wish I could run the wheels needed for that set-up.
Thanks for the C5 set-up David
davidmkelly.com
Old 08-05-2012   #8
What did you do for the E-Brake?
Old 08-05-2012   #9
Blue Flame Restorations
Will the late model GTO spare wheel work with the C6 calipers and rotor size?
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 08-05-2012   #10
Dave,
The C6 adapters look smaller but it looks as if the bolt holes for the caliper attaching to the spindle match up. Looks like with spacers and re-engineering of the spindle holes, you could eliminate the adapter unless you need it to add clearance for the 14" rotors. But that's what the bolt bosses on the C6Z er may be for. Would need to measure "height" of caliper compared to C4. Should be .5" taller. Anyway u could tell us that Dave?
