Old 05-23-2006   #1
2lpzr1s
Default Oil seperator for the pvc system
Has anyone come up with a workable oil seperator for the pvc tract after the valves. What parts did ya use where did ya get them? Loco bobs cool engine looks like he has them.
2lpzr1s is offline   Reply With Quote
Old 05-23-2006   #2
tf95ZR1
tf95ZR1's Avatar
Default Re: Oil seperator for the pvc system
Try
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
for a start. Can't vouch for them, but its an idea.......
Old 05-25-2006   #3
ZR1 MK
A small tank and hose will do it. Nothing special needed.
Mike
427 cu in LT5
[URL="http://zr1mk.weebly.com"]http://zr1mk.weebly.com[/URL]
ZR1 MK is offline   Reply With Quote
Old 05-26-2006   #4
2lpzr1s
Thanx for the idea. Where have those of you that have done this mount the tank. also how often does it need to be drained. thanx
Old 05-27-2006   #5
Locobob
My catch can began life as a stainless steel bathroom soap dispenser, welded two bungs on top for the in and out lines and one on the bottom for a drain ****. I chose the can because of its size - it fits nicely just forward of the master cylinder along the inner fender. I fabbed up a bracket to mount it to the existing inner fender bolts. I drained it after driving about 1K miles and got a little under 1 cup of oil out of it. I would have rather just bought an existing product but all of them that I found were to big to fit where I wanted to put it. The larger cans can be easily mounted in the well in front of the tire but you'll have to route more hose to get it there and then back to the plenum.
Robert
Old 06-03-2006   #6
UKZR1
UKZR1's Avatar
Originally Posted by tf95ZR1
Try
I bought a very similarlooking product from ebay.co.uk a while back. Looks to be good quality and well finished. I havent installed it yet as my engines out being worked on. At the price you can't really go wrong. I would probably get some better hose as the stuff supplied is a bit cheap looking
Red/red 90 #1281 (UK)
Marc Haibeck 368
B&B, Brembos
DRM suspension
Known as 'Gixer' on corvettechat.co.uk
www.corvetteclips.co.uk
UKZR1 is offline   Reply With Quote
