Old 07-27-2012   #1
sledfan2
Default reverse/backup switch source
Does anyone know were or who sells the reverse lamp switch. Autozone shows it, but its been over a year since I started asking when it will be available with the usual, got no idea response. Thanks..
sledfan2 is offline   Reply With Quote
Old 07-27-2012   #2
efnfast
Default Re: reverse/backup switch source
I think I bought mine from Corvette Central. I'll check when I get home. BTW, I cut off a large open ended wrench to reinstall it. It's tight up there.
Old 07-27-2012   #3
efnfast
Or I could just go on line and check. Corvette Central search for back up switch-$39.95
Old 07-27-2012   #4
VetteMed
Yep, that's where I bought mine. fits fine, but has a pigtail connector instead of the stock style.
Old 07-27-2012   #5
scottfab
scottfab's Avatar
A few things to be aware of when experiencing problems and before replacing the switch.
1. is the current switch in tight? I've seen them back out 1/4 turn and then fail to work.
2. Has the switch been removed and reinstalled? Did the steel ball bearing fall out? When you remove the switch there is a ball bearing that is in the hole that the switch goes in.
3. I've seen some switches that mount with a washer. If the switch becomes warn and intermittent chances are the plunger is not going in far enough. Remove the washer and reinstall the switch.
Scott
Old 07-28-2012   #6
sledfan2
Thanks for the info. The one in the vehicle was removed and inspected and it ohms open with the plunger ball depressed as far as you can push it in. So I would say its no good. I will go with the corvette central one no biggie on swapping the pigtail. Thanks again.
Old 07-28-2012   #7
scottfab
scottfab's Avatar
as a final check when you get your new put them side by side and do the same test.
Scott
