Old 07-25-2012   #1
sdycke
Default ex manifold bolts falling out?
I just noticed several of my exhaust mainifold bolts are missing (that I can see). weird. Vibrated loose? Are these cars known for this? The threaded holes are shinny on some....recent loss? My question is do these cars come with 16/side like one would think? FSM pp 6A2-33 shows 6 which almost corresponds to the ones I have left....Very wierd....And can you get the spacers anywhere.......thanks
sdycke is offline   Reply With Quote
Old 07-25-2012   #2
DaveK
Default Re: ex manifold bolts falling out?
I don't believe that they were all installed from the factory. Someone else can confirm I'm sure.
1991 #1516 Black/Black
davidmkelly.com
"Speed is often confused with insight." - Johan Cruijff
Old 07-25-2012   #3
Pete
Pete's Avatar
Yes.
Came like that from the factory.
On my headers i only have 2 per tube across/kiddie corner of each other.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 07-25-2012   #4
secondchance
No - exhaust bolts are not falling out. We, the WAZOO gang, have installed 3 or 4 headers and in all cases noted only 6 or so bolts were actually used per side for install at the factory although early LT5s have 16 bolt holes per side and 93+ cars have 14 bolt holes per side (top left and top right has dowels instead of bolt holes).
Old 07-25-2012   #5
VetteMed
Thanks to the thick flanges, and very square sealing surfaces, few bolts are required in order to maintain adequate sealing.
Old 07-26-2012   #6
sdycke
Thank you so much! You guys are great! Who would have thought?
Old 07-26-2012   #7
mgbrv8
Yes when i removed my factory exhaust there was a number of bolts missing. When I put the obx's on I put them all in
Dave
