Old 07-22-2012   #1
Default shifter bobbing up and down on accel
Going to recheck the C-beam bolts, but under hard accel the shifter is moving up about 1/2" maybe more....any other possibilities? This is on the 90...pretty confident I torqued to 37 and 59
Old 07-22-2012   #2
Default Re: shifter bobbing up and down on accel
Does it have the Beam plates?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 07-22-2012   #3
VetteMed
Lee, I had the same problem when I didn't completely clean the mating surfaces of the C-beam and of the transmission and differential. The bolts were torqued properly, but a few bits of the OEM adhesive were preventing flush fitment.
Of course, a worn or broken motor mount or batwing mount can do the same thing. But, if you've had the c-beam off recently, I'd want to check that there's no adhesive or debris preventing proper mating.
Old 07-22-2012   #4
scottfab
scottfab's Avatar
Yah, re-tighten bolts but check trans cross member and motor mounts too.
Scott
Old 07-22-2012   #5
No trans "cross member" on a ZR-1 (ZF) transmission. That leaves motor mounts, C-beam joints, and the "bat wing" bushings on the differential. Ya have ta go back to C3s to come across cross members for the trans.
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 07-22-2012   #6
Loos beam bolts.....surprised as my torque wrench was still set for them, and I used the 02 wrench to tighten...hopefully problem solved
did manage to take a nice 21MM deep socket to the eye
Old 07-22-2012   #7
rhipsher
rhipsher's Avatar
Lol! I took a Spicer Ujoint cap to the fore head while installing. I bled like a siv.
Old 07-22-2012   #8
scottfab
scottfab's Avatar
P.
Yup and my C3 had one. Brain fade. It's all that bike riding and fresh air. Well that and I haven't had to do anything under there since I rebuilt my ZF6.
Scott
Old 07-23-2012   #9
you leave your torque wrench set? I always Zero it out after use..
but yeah not surprised the bolts were loose
Old 07-23-2012   #10
scottfab
scottfab's Avatar
I loosen it also. Leaving it set is suppose to negatively effect the accuracy.
Scott
