Old 07-21-2012   #1
Default What a difference a gear makes!
Got Roza Nero back from Al's with now 3.73 gear installed. It's a real improvement over the stock 3.45s BUT 19" wheels.
Some observations:
1. Speedo error cut in half. Haven't changed anything else yet.
2. 6th gear now usable cruise gear under 80mph.
3. 4th and 5th now feel like passing gears.
4. MPG improved due to better rpm band. Also more accurate MPH and ODO.
5. RPMs don't drop as much between gears so it feels like you are staying closer to the power band. Better acceleration coming out of curves and ramps.
6. Much reduced exhaust drone at cruise due to higher rpm.
I can see now why something like a 3.90 would have been the preferred gear by LPE. With the Z06 wheels, I would do that next time. But for now, the 3.73s translate to something like a 3.60 gear on 19s.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 07-21-2012   #2
mike100
Default Re: What a difference a gear makes!
I had a chance to talk to a C6-Z06 owner who used to have a ZR-1 and he said the 3.73's was one of the better mods he did (stock tire size).
Old 07-21-2012   #3
902066
OK, just to be a party pooper, [because I probably do it well]. I have stock tire sizes and 3:73 gears. I wish I had gone with a 3:90 or 4:10 gear. 3:73 is a small improvement over stock, but not enough to justify the effort and cost.
902066 is offline   Reply With Quote
Old 07-21-2012   #4
Blue Flame Restorations
I have no experience driving any ZR-1 except my own but I LOVE my 4:10's!!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 07-22-2012   #5
With only 113 posts, I get the party pooper!!
With the additional power and torque from the mods on my motor, I can easily tell the diff. Maybe stock is a different matter. I'd probably do 4.10s in that case and could see your point.
Old 07-22-2012   #6
Hib Halverson
I've always wanted to put 3.73s in my 95. I math'ed that out one time and with the wider rpm range of my engine with its Automaster "Streetskinner" package of mods, the car would still do 180-mph in fifth but would accelerate just a little quicker.
Some day....
All I need is time...
Well, money, too.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 07-22-2012   #7
RICKYRJ1
RICKYRJ1's Avatar
Thanks to WAZOO I also run 3.73's. I am very satisfied with them, I roll on a 19" wheel. I do feel I would also be happy with 3.90's or 4.10's as well
Old 07-22-2012   #8
Some observations:
3.73/3.45 ≈ 1.08 (or approx 8% increase in torque in all gears) is nice.
Well, technically, the ratio between gears (in the ZF) did not change, so all things being equal, the rpm would drop the same amount as before.
However, I can see the grin factor coming from the fact the rpm would be higher up the torque curve of the LT5 after shifting, which when combinded with the higher ratio ring gear would definately affect the "seat of the pants!"
If that is true, then your speedo would register higher than it did with the 3.45 gear for a given speed. I get the impression from what you said that the speedo is still reading low compared to distance/time calc or GPS, no?
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 07-22-2012   #9
Paul,
Yes the speedo was reading 10mph slower at 70, now it's 5mph. The speedo gear is set up for 4.10s I believe. I checked my speed using the GPS of the
AVIC-D2.
As for the rpm drop, if what you are saying is the the change in rpm would stay constant, I'd agree. It's happening at higher rpms however.
Old 07-22-2012   #10
My plan is for 4.10s to be installed in the Fall
