Old 07-16-2012   #1
RobinTibbetts
Default Flywheel weights
I am replacing my duel mass flywheel with a slightly used flywheel. Does anyone know where I can get the weights I need to place in the new flywheel?
RobinTibbetts is offline   Reply With Quote
Old 07-16-2012   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Flywheel weights
Provided they were originally installed remove the weights from your old flywheel and install them in the same location on the replacement flywheel assuming it is also a factory dual mass. Note not all engines required trim ballancing so your old flywheel may not have any weights.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-17-2012   #3
brodykelly
brodykelly's Avatar
got mine from www.newgmparts.com 2 bucks a piece, below is info.
Order Status Details Order Date: 4/16/12 3:1 PM DescriptionQtyPriceCore PriceTotal PriceOEM Catalog
PIN-ENG B 4 $2.02$0.00$8.08 Status: Sent Sub Total$8.08Tax$0.00Standard Ground - Shipping$9.99 Handling Fee$2.00 Total $20.07
brodykelly is offline   Reply With Quote
Old 07-17-2012   #4
RobinTibbetts
Thanks for the help.
Old 07-18-2012   #5
RobinTibbetts
How do you remove the weights from the flywheel without damaging them or the flywheel?
Old 07-18-2012   #6
brodykelly
brodykelly's Avatar
i removed the weights from the used one i was replacing my orig one with by spraying wd40 on them then using the smallest drill bit i could in my drill press and started slowly drilling them out and they actually stuck to the bit and spun out with no help by me. I knew i had new ones coming in the mail to put back in this flywheel in same location as my orig. flywheels weight location...all worked fine and she runs as smooth as before....hope it works for you sir....so you know each weight is 2g, haibeck suggested getting some round stock and making your own if i couldn't locate new ones but i found the new ones on the previous mentioned website above.... brody p.
