Old 05-17-2006   #1
jrd1990zr1
jrd1990zr1's Avatar
Default Intermittent high level brake light
Anyone had a problem with an intermittent high level brake light. Are there any common problems? Is the circuit feed from two fuses?
Thanks.
Old 05-18-2006   #2
Aurora40
Aurora40's Avatar
Default Re: Intermittent high level brake light
It is fed from a separate switch on the brake pedal. It's not an uncommon problem. My car had an inop high mounted brake light, and the switch was the problem. Fortunately it's a pretty easy fix.
Old 05-18-2006   #3
jrd1990zr1
jrd1990zr1's Avatar
Seriously, how do you twist yourself to get to this spot under the dash? Is there a secret to getting to the switch?
Thanks, John
Old 05-18-2006   #4
Aurora40
Aurora40's Avatar
um, I just sort of laid on my back a bit. It's not overly comfortable but not impossible. It all comes out and goes in pretty easily once you reach it.
Old 08-13-2007   #5
thxalot
Hi Guys,
Mine is down too. Not just intermittent, it's out completely. No voltage making it's way up to the fixture on the roof.
Do either of you have the part number for that switch? Is it diagrammed in the shop manual?
Thanks for your help in advance.
-Burt
thxalot is offline   Reply With Quote
Old 08-13-2007   #6
Aurora40
Aurora40's Avatar
It is part # 25529860. Also ACDelco #D852A
http://198.208.187.182/internet/Part...cpartnbr=D852A
Old 08-13-2007   #7
thxalot
Thanks Bob,
I got it ordered for $9 bucks and I am on my way to a fixed up ride!
Say, I noticed that you have a very sharp looking ride! Particularly near and dear to my own (red on red '90 with GM 5-spokes). I noticed the funky intake as something different though.
What did you produce on the Superflow dyno in your picture?
I am hoping to get mine on a roller some time soon.
Thanks again for the quick help.
-Burt
Old 08-13-2007   #8
jrd1990zr1
jrd1990zr1's Avatar
Smile Re: Intermittent high level brake light
Originally Posted by thxalot
Thanks Bob,
-Burt
Wow!!!
Where did you find one for $9. I think I want a spare.
Fixed mine with 1 wrap of electrical tape to make it seat in the bracket more securely. Looks like when you release the brake petal it pushes the switch back in the bracket, eventially the petal does not make contact.
Thanks for the info.
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 08-14-2007   #9
Aurora40
Aurora40's Avatar
Heheh, yeah mine is the other red/red with 5-spokes. Thanks for the compliments.
The intake is the SLP Claw. Mostly it's on there for looks.
On the superflow, my car put down ~325 hp when it was all stock except a ported top end. With a cat-back exhaust it put down ~350 hp. I have since added headers but have not re-dynoed it on that same dyno. It did put down 385hp at Haibeck's, which is a dynojet. I suspect the Superflow reads lower as it's an eddy-current dyno. I would guess my car would put down around 370hp on it now.
Thanks Bob,
-Burt
Old 08-14-2007   #10
tf95ZR1
tf95ZR1's Avatar
Thanks, John
If you think that's bad, try lying on your back under the dash trying to remove the (6) nuts holding the brake booster to the fire wall so you can get at your cam covers. It helps to remove the seat, but then you get to contend with the seat mount bars. But I digress.......
