07-03-2012 | #1 |
idle problem
Hi guys....
i have a little problem with my 1990 zr-1. When i start the engine it's run great...but after some minutes it run bad...it's seem like lose rpm and it's shake for few second, after it run ok...and after few minute it run bad for few seconds. if i push oh the accellerator pedal the engine run good. I change: Spark and fuel filter. I test the fule pressure and it's ok...50 psi on both pumps without run engine. What can i check??? Thanks to all!!!! Max |
07-03-2012 | #2 | |
Re: idle problem
Can you make a sound recording of it while running rough?
07-03-2012 | #3 |
Re: idle problem
Max,
To help the experts (not me) diagnose your problem, give us some more info. What have you done to your car recently? Have you changed injectors? (are they original) Do you drive your Z regularly? (once a week, two weeks, month?) David |
07-03-2012 | #4 |
Re: idle problem
Sounds like a ignition coil going south, breaking down and coming back randomely or fuel contamination, water in the fuel will make the thing run real ugly at times, water tends to not burn very well for some reason!!!!!
New fuel filter will catch particles of crud but will still allow water to be squeezed through it and will stumble all over the place until corrected. Have you tried any fuel conditioner or fuel drier which seperates the larger water puddles and keeps the water in smaller amounts so it will pass more easily? Did the problem start to happen shortly after filling up the petrol tank recently? Good luck Gibby |
07-04-2012 | #5 | |
Re: idle problem
i have original injectors (the car have 18500miles) I drive the car sometimes...also once two or three weeks.... :-) |
07-04-2012 | #6 |
Re: idle problem
test injectors
http://www.zr1.net/forum/showthread.php?p=17299 test coils http://www.zr1.net/forum/showthread.php?p=70781 Use Solutions to help get to your problems and fix them http://www.zr1.net/forum/showthread.php?t=16778
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif "The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC " We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln |
07-04-2012 | #7 |
Re: idle problem
Hi zrwhat...
i think is an alimention problem too...i have leave the car sit down for about 45 days and after this sometimes run bad at idle...iill try to add a gasoline cleaner ;-) |
07-04-2012 | #8 | |
Re: idle problem
Hi...very interesting post!!!! I'll read all when i have just a little time!!! Thanks |
