Old 05-23-2012   #1
efnfast
Default Lumbar pump
Doing a search, all I seem to find is repair it with a rubber glove. Don't know if the diaphram is torn or not, but all the pump does is go "thunk-thunk". I would think if the diaphram were torn it would run but not pump. Mine doesn't seem to even run.
Thanks for any help. Steve
Old 05-23-2012   #2
VetteMed
Default Re: Lumbar pump
Correct, the pumps with the bad diaphragm will run but not build any pressure.
The 94+ seats used a different style pump from the 90-93, just so you know. Not sure what year your car is.
I'd suggest pulling the lower seat cushion, to see if you've got voltage at the connector for the pump when you hit the switch. If so, then perhaps the motor of the pump is bad.
Old 05-23-2012   #3
efnfast
Thanks Vettemed, the car is a 1990. I should have mentioned that, I saw looking through posts that they were different. No easy place to check voltage, but it pulls about 2 amps when I hit the switch and goes thunk.
Old 05-23-2012   #4
VetteMed
can't you disconnect the harness where it plugs into the pump and measure voltage at the connector terminals?
If it's the pump going "thunk" and not a relay, then it sounds like a bad motor to me.
Old 05-23-2012   #5
efnfast
And just where might I find a new motor these days?
Old 05-23-2012   #6
VetteMed
probably not gonna find new, used will be your best bet I suspect.
Old 05-23-2012   #7
Corvettes White
Originally Posted by efnfast View Post
...repair it with a rubber glove. ...Thanks for any help. Steve
I cut a diaphram from a thin bicycle tube (not the thorn proof ) The pump now works and was very easy to accomplish. To the point that even if I did need a new 20 year old used motor, I would change out the diaphram first anyway.
George
Corvettes White is offline   Reply With Quote
Old 05-24-2012   #8
Hammer
Hammer's Avatar
Talking Re: Lumbar pump
If you haven't opened the motor up, I would suggest doing that before looking for a new one. When I fixed mine, the diaphram was hung up inside. I had to free the motor thingee from it and then the motor worked. maybe your motor has encountered the same problem.
Old 05-24-2012   #9
I was going to post the same.
I know I had a few pumps at one time, I am not sure I have any extras, but I bet the piece the connects the pump to the diaphragm is stuck
Old 05-24-2012   #10
scottfab
scottfab's Avatar
As has been mentioned several times. These are very fixable. On a scale of difficulty from 1 - 10 I'd put this as a 2.
A "1" would be changing you oil.
I too used thin inner tube to fix mine in 99. Hasn't failed again since. Others have used kitchen/bathroom cleaning gloves.
Scott
