Old 05-19-2012   #1
Bob Eyres
Default C4 Chassis Stiffeners from Killebrew
Here's an article mentioning Gordon's chassis stiffener kit:
:http://www.amosauto.com/Articles/Gen...e-tighten-up-1
Has anyone tried this on a ZR-1? Effective? Results?
Sorry, if this has already been discussed elsewhere.
Old 05-19-2012   #2
VetteMed
Default Re: C4 Chassis Stiffeners from Killebrew
Forum member -=Jeff=- is running them, I believe. He seems to be happy with them.
I installed a convertible x-brace and am very happy with the improvement in overall feel of the chassis, and reduction in shakes and rattles. I am curious to compare the difference but not willing to drop $500 to do so.
Old 05-19-2012   #3
Bob Eyres
I wonder how it would do with both? Or are the attachments in the same place?
Now let's see, if you used these braces, plus a convertible brace, plus one of those stiffeners for the Targa bar to windshield frame, plus a four point roll cage, that sucka would be damn rigid.
But you'd probably have added an extra 100 lbs. of unwanted weight.
Old 05-19-2012   #4
VetteMed
The front attachments share the same pre-threaded holes. I think it might be possible to "stack" the two devices, but I can't be sure.
The rear attachments are in different locations, I think. The x-brace goes to the recess just inboard of the jacking points in the rear. The above braces I think attach to the dogbone mount bracket.
Old 05-19-2012   #5
What do people w headers do? I know =Jeff= has 2" headers and Gordon's bracing run along the rocker panel. They're designed to tie front and back of the chassis.
Old 05-19-2012   #6
VetteMed
I have Jeal headers, I have about 1/8" clearance between the driver's side ball joint clamp and the x-brace.
Old 05-19-2012   #7
batchman
Very interested to hear your positive result. The rules I race under would allow this addition, as I can use any part on any C4. Any chance you have pics, especially near the headers?
Best,
- Jeff
Old 05-19-2012   #8
VetteMed
Best,
- Jeff
Hey Jeff, I don't have any pictures -- but I may have some time in the next few days to jack the car up to take a few pics for you.
-Andrew
Old 05-21-2012   #9
batchman
-Andrew
Next time you're under it that would be awesome. I'll be looking forward!
- Jeff
Old 05-21-2012   #10
I have them... I think they work as Advertised. I actually noticed an improvement when I left the place I had them installed at.
my car also would creak/twist pulling n my driveway, it no longer does it.
The braces were installed in 2010 and I have been happy with them since. I have adjusted them twice mainly because they were the 1st prototypes that were manufactured by vette2vette.. there have been improvements on the bars as far as getting a wrench on to tighten them ( something mine don't have)
Overall I would buy them again for any C4..
