Old 05-08-2012   #1
SteelBlueZR1
Default Factory Exhaust Resonator Removal and Free Flowing Alternatives
How many of you have tried keeping your stock 2.75" factory ZR1 exhaust system and just replacing the 1990-92 restrictive resonator with an aftermarket freer flowing resonator or x pipe?
Haibeck says the stock resonator is a major exhaust flow restriction costing about 20hp, due to the resonator core reducing to 1 5/8” ID.
What is the best product to replace the resonator with to maintain the low noise and no resonance I currently enjoy?
I prefer not to go to a straight pipe or crossover, but rather find a replacement resonator with straight through 2.5-3" pipes. Has anyone tried the DynoMax® Ultra Flo™ X performance stainless steel mufflers with 3-in. diameter internal X-pipe balance tubes?
I am concerned about fitment issues, so what have you tried that fits the factory pipes and doesn't drone?
Old 05-08-2012   #2
Default Re: Factory Exhaust Resonator Removal and Free Flowing Alternatives
Well you could use a Corsa resonator. The xpipe would be better flowing but you will pick up resonance
Old 05-08-2012   #3
Gunny
Gunny's Avatar
AFAIK there are only 2 systems that have NO drone ... stock and Corsa ... the fitment is fine on either system. Corsa is reasonably tame until you get above 2500-2800 rpm then it is very loud (at least to me).
The early (90-92) stock systems were not only restrictive at the resonator but also at the mufflers ... can't remember the neck down at the muffs but I believe it was about 2" or less. Also, I think that only one tip flowed; the other was for appearance. The later stock systems were less restrictive and if you want to stay with a stock system it's probably easier to get one than try to mod or adapt an early model to fit your needs; otherwise you're looking at a variety of 3rd party exhaust systems. Finding the "perfect" exhaust system for all situations is a tough, perhaps impossible task ... I know since I currently have 3 systems hanging on the garage wall plus a Corsa system currently installed. Every system I have (except for the stock 90) has a certain appeal to me but also some drawbacks ... I'm looking for the happy medium which may not exist.
Do a search on this forum ... the guys in Chicago are doing some really nice things with larger systems, C6 flapper mufflers, etc. I haven't heard any of these systems yet but plan to next week at BG ... great place to hear a lot of different exhaust systems.
George
George Jones
Founding Member #14
www.zrwon.com
Old 05-08-2012   #4
efnfast
I'm running a brand new OBX system, headers and exhaust. No drone. If you're coming to BG, you are welcome to come for a ride with me and listen. Maybe you can drive, maybe.
Old 05-08-2012   #5
SteelBlueZR1
Thanks for all the feedback guys. I would love to hear the new OBX system... But I really had my heart set on finding a replacement resonator for the stock 1991 exhaust. The 1991 mufflers according to Chevy are 40% larger than the 1990's and have much less backpressure, plus I like em quiet.
Bert Rankin
1991 ZR1 Steel Blue / Steel Blue
#1029
Haibeck chip, slotted rotors, camber brace, C-beam plates, OBX exhaust, Nitto NT555 tires
[SIGPIC][/SIGPIC]
Old 05-08-2012   #6
I have a corsa resonator in my attic. If you want to get it fit at a shop to try it out. I paid $200 for it I would let it go at that plus shipping.
Old 05-08-2012   #7
mike100
stock muffs are quiet even without the factory resonator. There might be a slight bit more rumble, but rest assured that you won't feel fatigued on the highway after a long run at 70 mph.
I would easily say that my stock 90 pipes and mufflers with the magnaflow x-pipe are quieter than Corsa at pretty much every power level.
I used the magnaflow x-pipe from their x-pipe and resonator combo- just hacked off the chrome resonator can due to ground clearance concerns.
Old 05-08-2012   #8
mike100
I bought this from Hans when I got the stock exhaust, but ended up only using the x-pipe. You could just have your exhaust guy make one, but you could also buy this pipe for $85 from Summit.
Old 05-08-2012   #9
Having all three exhaust systems I would have to disagree with that assessment. However in the end Bert can make up his own mind as it will cost him to try systems out.
Old 05-08-2012   #10
sammy
you could also buy a 3in xpipe from summit about 80 bucks . then buy 2 dyno max super turbo mufflers 3in inlet and dual 21/2 in outlets about 150 for both hack off the zr1 tips from the stk exhaust and have a nice no drone exhaust for about 350 and it would look stk . idf you pm me your email i will send you a utube video of my car going down the drag strip with this exhaust on my 92 .
