05-03-2012 | #1 |
Headlights
I have noticed recently that when I start my ZR-1, the left front headlight pops up after driving for maybe 30 seconds then it goes down. I seldom drive at night but when I did last week, after starting the car only the left headlight came up, turned the car off and started it again and both headlights came up. A night or two later only the left headlight came up.
I turned the car off and just turning the headlight switch both headlights came up. The next morning just turning on the headlight switch both headlights came up again, I tried it at least three times and every time both headlights popped up. Later that day I tried the same thing again but this time the right headlight didn't pop up. I was wondering if this could be a electrical problem. This season is starting out like a season from hell. I would appreciate any advice in regards to this issue. Thank You |
05-03-2012 | #2 |
Re: Headlights
1991 #1516 Black/Black davidmkelly.com "Speed is often confused with insight." - Johan Cruijff |
05-03-2012 | #3 | |
Re: Headlights
David |
05-03-2012 | #4 |
Re: Headlights
Concur its the Delran bushings. They will need to be replaced
05-04-2012 | #5 |
Re: Headlights
Due to the car being 22 years young, I can see how the bushings would require replacing. I will endeavour to obtain headlight bushings. Thank you all for your replies to my thread. I contacted Ecklers Supplier and ordered bushings as well as brass Gear. Thank you
CHEERS! Last edited by Crusin; 05-04-2012 at 06:26 PM. |
05-04-2012 | #6 |
Re: Headlights
Wait till you see the old Delran bushings! Just a pile of "gravel" is all that's usually left! Good old GM!
05-05-2012 | #7 |
Re: Headlights
its the bushings. about three weeks ago i bought a regular 91 vette for resale and the first thing i had to do to it was replace the bushings. a white powder was all that was left of them.
05-05-2012 | #8 |
Re: Headlights
The bushings are in the HELP section of your local AutoZone and others.
Look for the pack with 3 white plastic bushings - I think they are for a Ford truck - and about $8.00 a pack. The gears are probably OK because the bushings poop out first. Do the headlights automatically open when you start a Canadian car - is that the DRL thing?
05-05-2012 | #9 |
Re: Headlights
Yes, that's the Canadian DRL option.
06-23-2012 | #10 |
Re: Headlights
Thanks for your help guys. I replaced the H/L gears and bushings. Problem solved.
